RICHIE HIGH PSI
- May 25, 2001
went to the track today, and the numbers seemed way off
EGT 1837
O2 FROM SCANMASTER=720
KNOCK=0
ONLY 24 PSI
BEST RUN WAS 12.01@111MPH
Last year same combo went 11.23@118
I have 50lbs inj., 62-1 turbo,ATR headers,9-11 converter,ported heads,hemco upper,front mt,28x11.50x15 et streets,1.67 60ft,.
I tried setting fp as high as 49 static.
what else can I do??
The only problem I can see with car is cross over pipe is leaking, and turbo flange to header flange is leaking, these are small leaks, can this be the problem?
Richie
EGT 1837
KNOCK=0
ONLY 24 PSI
Richie
