Bruce Urie
The Ventures,CCR forever!
I've got a 2008 Jeep Grand Cherokee Laredo...LOVE IT!!!!!.....pinion seal has been leaking....though I loved it leaking as it kept tailgaters way, WAY behind me all of the time!!!! (fine spray of oil backed them off every time
) I just got tired of cleaning the rear window after every drive, plus losing differential oil is not good.
Had to get the Jeep up in the air in order to disconnect the driveshaft, pinion flange bolt, pinion flange and seal...problem was, using my two jacks just couldn't get the Jeep up high enough....jack stands only went up to 18 inches. This model Jeep sits way high in the air (chassis)
Well, dork here, got the grand idea of setting the jack stands on an old disc brake rotor, with the flat side of the rotor facing upwards.....put each stand on one of those....did the trick, got it high enough to just clear the differential by 1/2" over my chest.....BUT....had a bad feeling, did not feel comfortable with this idea....warning bells going off at 1,000 times a second. I had shaken the Jeep back and forth to check stability....a little wobble from side to side.....uh.....hmm.
Thus, I made a long trip to Harbor Freight and bought two 6 ton jack stands...set me back $87.....expensive. Heavy as hell.
Today I put a 2x4 block on the jack pad, jacked up the Jeep higher, wrestled the 6 ton jack stands under the Jeep, got it up very high.....nice and steady.....about 30 inches high now. Plenty of room, perfect for me to complete the job SAFELY.
That's the whole point of this story.....do not ever jerryrig anything that would threaten your life......I kept feeling very, very uncomfortable just even LOOKING at the old jackstands standing on disc rotors....sure, it was "kind" of steady, but no cigar. Kind of felt stupid, me. Like a new first grader.
I realized that my life is worth more than an $87 pair of jack stands. Even my wife was happy with the new jack stands.....well worth it for safety.....she's breathing a sigh of relief and I even got a kiss from her for doing the right thing for once.
So, when fooling around with your cars/trucks, always evaluate your personal safety FIRST....when no WARNING BELLS are going off in your head, you are ahead of the game.
I know a garage two post lift would be a great thing for me...problem is, in both of my garages, there are cracks in the cement within the 3 foot limit of where the posts would go, as I was going to get a lift earlier last year......those cracks.....well, too close to the posts, so I was very disappointed. Sad even.
I'll live with jacking up vehicles, placing SAFE stands under it as long as I can.....it does hurt my back quite a bit, all that jacking and crawling around everywhere, maneuvering stands, etc. but it's better than being crushed to death because of poor judgement.
I hope I've opened a few eyes here on this matter. Always take your personal safety very seriously.
I'm glad I did.....now I'm not intimidated like I used to be when crawling under this 2008 locomotive here.
Bruce '87 Grand National
