After just having finished replacing my timing chain, I was trying to prime the oil pump but something very strange is happening.
For some unknown reason, the oil pump shaft appears to be binding up somehow. While using a drill and priming tool, I originally thought that I just didn't tighten the drill chuck enough but after trying to turn the shaft manually with a screwdriver I noticed the problem. What happens is that you can turn it clockwise only so far and then if you try to turn it counterclockwise, it'll bind up at just a little under 360 degrees from where you first started.
The oil pump itself appeared to be working fine before my timing chain let go a few weeks back. It's a Melling HV kit that I installed myself when I first got the car (about 3 months ago) and while I know that could be the problem, I'm trying to explore my other options before having to pull it apart again.
The other strange thing is that if I put the cam sensor back in the car will actually run, albeit with no oil pressure. This seemed kinda odd because I can't see how the camshaft sensor could turn if it's connected to an oil pump shaft that won't turn.
Any thoughts as to why it's binding and what a possible fix might be?
Thanks,
Christopher
Thanks,
Christopher
