V Vin71 New Member Joined Jun 19, 2008 Mar 22, 2012 #1 What are the best brands and type for GN if improving top end speed is the goal? Appreciate the help.
W we4Mateo Double you eee what? Joined Apr 7, 2010 Mar 23, 2012 #2 Do a search on "valvesprings." There are a lot of different opinions out there but it depends on your setup, so research here first, then post info about your specific combo if you want more help.
J just plain john El Camino a Go-Go! Joined Feb 24, 2007 Mar 23, 2012 #3 Comp 980's are a common choice for a flat tappet cam.
BobbyBuick Well-Known Member Joined May 24, 2001 Mar 23, 2012 #4 Dennis Kirban has a set and sells a tool to do the job
F forcefed3.8's Buckeye Bullet Joined May 26, 2002 Mar 23, 2012 #6 Comp 979's with the stock cup or Comp 980's without the cup for a stock cam.
