Valve cover off 1985 Park Ave?
corymc
Last night i was working on this guys 1985 PA and it had the 3.8 in it the valve covers look the same as on the TRs i was wondering if you can use them on the tr? Well the only one that i would want to use is the pasengers side on the TR and switch it out with the one closest to the firewal on the park ave.
I use the closest one to the radiator off the 85 front drive. This way, you can utilize a second breather as on the driver side of your TR. The only problem is the cover from the 85 is full sized and not recessed for the AC box. There may be some slight contact. You can use a bar to dimple the AC box heat shield to fix this problem if it occurs.
