boosted231
- Sep 13, 2003
I am trying to run down some vacuum leaks and I have a few questions. When I apply vacuum to the large nipple on the egr solenoid and hold my finger in the back where the filter goes, the solenoid does not hold vacuum. Am I supposed to leave the little nipple open?
The large round ball attached to the charcol cannister will not hold vacuum either when I attach vacuum to the nipple, does this indicate that it is bad?
How do you check the vacuum solenoid on the charcol cannister, I have removed it but not sure how to check if it is bad. Both vacuum check valves going to both the cannister and eger solenoid were bad and I ordered from GM. Thanks
