Using stock oil lines with B&M cooler
0-60n4
FYI for anyone needing to install an oil cooler, when using a front mount IC.
I replaced the radiator with an Fbody unit and needed an aux. oil cooler. I got the B&M 70273. I was able to mount it behind the front sway bar and use these fittings from Fastenall to connect the factory flared fittings to the cooler.
Fastenal Part No. (SKU): 69645
1/2" Female Inverted Flare x 1/2" Male NPT Brass Straight Connector
