Raymond Bunch
"Turbo Enthusiast"
- Mar 20, 2002
I am asking this question due to a lot of conflicting answers I've received. Here's my issue...
I'm currently running a single Walbro 340 (255), 80# inj, and Razors single alky nozzle set up. I can put on dual if need be for added fuel.
My current goal is to run a 10.99 on a stock unopened engine, with a bison 62/62 Turbo, 3200 stall, THDP, on drag Radials, using 3:45 rear gears. I have everything in place to do this with the exception of a bigger fuel pump that some people seem to think I may need, while others think I will be good down to a 10.50 ET using my single pump. I also recently installed a Casper Volt Booster, Racetronix injector harness with booster.
What your thoughts? The car runs excellent right now with 20psi. My concern is will I run into any issues when I run upwards of 28-30 psi ???
I will be going to race this coming Friday. Depending on what you guys say here, I will either keep the 80# in place! or I will stick the 60# back in before Friday and call it a day. Don't want too, If I don't have Too.
Thanks guys!
Thanks guys!
