F FastRegalWE2 Wish I had another Buick! Joined Jan 10, 2004 Aug 26, 2008 #1 anyone know anything about these turbos, has a T6 flange, Its off an old Detroit.
J JZ 97 SS 1500 Turbocharger Engineer Joined Jul 2, 2001 Aug 27, 2008 #2 FastRegalWE2 said: anyone know anything about these turbos, has a T6 flange, Its off an old Detroit. Click to expand... Do you have the tag off the turbo. The TV7101 had multiple models. Ranging from the 4XXXXXX-0001 all the way up to 002X. I can narrow it down for you exactly if you have the #'s.
F FastRegalWE2 Wish I had another Buick! Joined Jan 10, 2004 Oct 29, 2008 #3 5103760 is the part number thanks for the info
J JZ 97 SS 1500 Turbocharger Engineer Joined Jul 2, 2001 Oct 29, 2008 #4 FastRegalWE2 said: 5103760 is the part number thanks for the info Click to expand... 74mm comp wheel, 96mm turbine wheel and 1.39A/R housing. Turbo should make ~900-1000hp, but spool up is a bit slow.
F FastRegalWE2 Wish I had another Buick! Joined Jan 10, 2004 Oct 29, 2008 #5 JZ 97 SS 1500 said: 74mm comp wheel, 96mm turbine wheel and 1.39A/R housing. Turbo should make ~900-1000hp, but spool up is a bit slow. Click to expand... wow, not too shabby. I really appreciate you looking that up for me. :biggrin:
N notacarlo eggs are liquid chicken Joined Jan 7, 2004 Oct 29, 2008 #6 JZ 97 SS 1500 said: but spool up is a bit slow. Click to expand... UNDERSTATEMENT
