Turbonetics GTK-850 and F.A.S.T classic ECM
UnderdogGN
I have a used FAST classic ecm for sale. Was all updated by Cal Hartline in 2011. Good shape, none of the wiring or sensors are included, just the ECM itself. The sticker was peeled off for a factory appearance.
Also have a nice barely used Turbonetics GTK-850 turbocharger. Was too big for the car it was on. Great shape, only 300 miles on it. Zero shaft play. Couple small blemishes in the paint due to it rubbing on something but does not affect anything at all. This turbo retails for $1695 from cottons where it was purchased.
Specs:
4" inlet
2.5" outlet
72mm billet compressor wheel
68mm billet turbine wheel
dual ceramic ball bearing
.85 A/R exhaust housing
Asking $1500 for everything or
$1200 just the turbo
$300 FAST ecm
Do you have the o2 sensor ?? O2 is married to the box even if its bad its better than none
I don't have the 02 sensor sorry. I know for sure you can order replacement fast 02 sensors that work, I picked one up over the summer
Also interested in trades for the turbo. Looking for aluminum small block chevy heads, dart, brodix, trick flow, edelbrock etc
