Finally got the car out on the highway after bolting on the Champion ported irons and while using the chip I had from the stock heads the wideband showed 14.0 at only 20lbs boost and I backed out immediatly.I had to add 18% fuel just to get the o2's to get under 11.0 at WOT which is usually my target.So it looks like I cant turn the boost up anymore cause the fuel is pretty much maxxed out.
Before adding the heads I could run 25lbs boost and subtract fuel.
Is this normal? I never would have guessed those heads flowed that much more.
