mikemcvaney
- Apr 20, 2009
Is porting and polishing the turbo plenum good for any power gains or will it simply cause the gas to puddle under the carb? Mike
I'll be showing how to in the turbo thread and starting an intake thread when I'm ready to open it up some. Keep tuned
sound like you have some cool new projects. can't wait to see this stuff.
I did this back in 11/2006 with my plenum. I don't have any before or after stats. It just seemed to be the thing to do if it's off the vehicle. No problems to this day with the fuel delivery. But I really don't know if it was beneficial, (it looks good though ).
You cleaned it up really nice Freddie. The area I've been looking at is just to the side of the carb mounting pad. Build it up some there so you can open the throat up.
That's an 83 intake isn't it Freddie?
As far as the throat, the new turbo is matched to the gasket from the original kit and it's the same size as the flange that mounts the plenum. I looked very carefully at it when I had everything apart and there has to be some serious work done to it to make it as big as it needs to be. It really is restrictive if you look at one of the TTA plenums.
but only in comparison if your using the 301 compressor right?
in stock form would you argue any improvement?
A.j.
Hey freddie, I've never seen pics of your ride. Could you make a thread and post them with some mods you have done? Pleeeeeease:biggrin:
That's an 83 intake isn't it Freddie? It really is restrictive if you look at one of the TTA plenums.
