87GN&98VET
- Jul 12, 2002
Hi all, need some advice here. When I go WOT from a stop, I begin lighting up my Caspers knock gauge (the middle yellow light) as the boost climbs in first gear. Ironically, the lights seem to occur as the tires are breaking loose. Has anyone ever had poor traction cause the knock gauge to light up? The boost peaks at about 18# in 1st, but when I jump on it while I'm moving (either downshifting into 2nd or staying in 3rd), the boost spikes to almost 20# then settles back to 17# but I get no lights on the knock gauge. That's why I'm asking if the poor traction is causing knock (or false knock) in first because I'm not getting anything in 2nd or 3rd.
Also, I'm already up to 47 psi with my stock injectors. If I am truly running lean, is it time to upgrade the injectors? The car is basically a 13k mile stocker (stock intercooler, turbo, etc.) with the usual beginner upgrades. I also have a 62mm Hemco intake plenum I'm going to put on and I'm not sure if that will eleviate my problem or make it worse. I appreciate any advice!
