T-Type Mike
- May 29, 2001
Guys, I am hoping to go to the track this weekend. I have been doing a bit of tuning on the car, using a snap-on scanner, and have some data. I think I need some help as to where to start.
Here are my readings at Idle and ranges
BLM is pegged at 150
TPS .43
IAC possition 54-61
INT- 134-149
MAF- 5
O2 XCOUNTS - ANYWHERE FROM 2-23??????
LV8- 28
RPM- fluctuates between 975-1025
The car is in closed loop
During my road test (65 mph) my readings were...
o2- 816
iac possition-101
tps- 2.78
lv8- 221
maf-184 gps
o2 x counts-3
Noticed A/F reading was not learned??????
2nd run at 3727 rpm
o2- 924
int- 128
tps -2.08
blm -150
iac possition_ 101
Lv8- 179
maf- 153
O2 Xcounts- 4
MAT- 30 celcius
THe car reads that it is rich, which is good. 44lbs FP line off using LUbrant 94 oct. 16 lbs boost with no knock. During my last blast around the block, which I was unable to record, I noticed that my LV8 went all the way up to 230. I also noticed the scanner read that I had 34 degrees of spark advance, Now guys where do I begin?? I know you guys are the guru's!! ANy help would be appreciated. Thanks, Mike
TPS .43
IAC possition 54-61
INT- 134-149
MAF- 5
LV8- 28
o2- 816
iac possition-101
tps- 2.78
lv8- 221
maf-184 gps
o2 x counts-3
2nd run at 3727 rpm
o2- 924
int- 128
tps -2.08
blm -150
iac possition_ 101
Lv8- 179
maf- 153
O2 Xcounts- 4
MAT- 30 celcius
