86GN-862+2
- Apr 19, 2008
Is the 200R4 in the TTA also a BRF? How does one ID it?
The speedometer hook up is also diffrent because gn has a mechanical speedometer and the tta is electric
I'm not 100% that is on the trans...I think that is on the back of the speedo.
I bought a GN trans and it bolted right in...
That same gas tank goes all the way back to the '82 cross fire fuel injected F-bodys.
Steve K.
The valve body, the plate between the v-body & case, a 10 vane front pump, and I think a different governor.
Steve K.
All good stuff to know. Thanks a bunch! Thought I had read about the fuel tank having a sump to keep a steady fuel supply when cornering. Maybe it was a different application? Like a pilot car for example? Anyway, all the TTA specifics are welcome!
Frank, I'm talking about a transmission governor. Not a engine governor.
Steve K.
Hi Steve,
I'm not sure what you are talking about? Are you talking about the servo? If so, it's a Corvette servo. I'm sorry but I'm at a loose here. Would you please explain
this to me so I can understand. I have never heard of this but I'm willing to learn.
