So it was brought up in my other post about stacked plate coolers possibly causing increases in cooling circuit pressures. I want to understand this concern better so I don't make a mistake re-doing my trans cooler lines and cooler. Also, it has been mentioned to me to not run both an external cooler and utilize the one in the radiator due to this also.
Is it because 2 coolers will cause the source side to increase pressure in order to push the fluid through both coolers? Are stacked plate coolers that restrictive? I see some advertised as "low pressure" drop..what causes the pressure drop which I am assuming is in the return side??
My previous setup which has been on there for 25 years did go through the radiator and a tube and fin ext cooler and the factory steel lines and I did not experience any trans issues running mid 11s for the last 10 years.
New setup will have new 3/8" hoses ran through the frame up to the front, eliminating the restrictive stock tubes. The stacked plate cooler I was leaning towards has 34 rows of plates in a 12x10 layout, with 34 rows, I don't understand how a -6an line could get restricted by 34 rows if that is the cause of the loss of pressure on the return and increase in pressure on the source side...or am I just completely off in my thinking?? Wouldn't be the first time...
Thanks in advance
Thanks in advance
