Trying to lower 2-3 PT shift point.
77 cruiser
I put the stock 2-3 shift spring back in had a blue from SK kit. Put in a slightly shorter TV plunger spring. CQ vb.
dank GN
BlackArts Automotive (661)993-8277
The shifts are controlled by the governor weights . If add weight it will shift sooner if u take weight away it will shift later .
mikestertwo
If you want to lower the 2-3 shift point without affecting the other shift points the best way is to put a larger diameter 2-3 shift valve in the valvebody.
