My new Summit Racing has a triple pass radiator in it in 4 different widths for GM vehicles.
My 1st experience with a two-pass radiator is on a friends 540 CI BBC down in Houston, TX. It is a high dollar Ron Davis radiator that is supposed to be like NASCAR uses? Anyway.... 100 deg day.... 700+ HP BBC.... idling forever..... thing never gets over 180°. Only drawback to the two-pass is that the inlet and outlet are on the same side.... which would make for some custom hoses and definately would really stick-out as not stock. With the new 3-pass, you can get the offset inlet/outlet like the original.
My car with a f-body alum radiator and a RJC FMIC, will creep up to 200+ pretty quick on a 90 deg day with the stock cooling fan. Granted, I've never tried to seal-off the radiator better than the factory did to enhance airflow or install the dual fans I have sitting under my workbench.......With that said, I have noticed I have to be running 50+ mph to make the cooling temps start dropping once I get near 200 deg.....even though I am running a 160 thermostat. What that tells me is it takes some serious air to keep my car cool on a 90 deg day...... so much that I don't think any amout of sealing off+dual fans will ever really be enough to run the air on a 100 deg day and not worry about overheating. I'd have to be sucking air at (the equivalent to) 50-60 MPH across the radiator to properly cool the car.
With that said, I really was toying wih the idea of the two pass until I see the three pass...... I bet I can make this work and it not look any more out-of-place than the current f-body radiator does. Even better would be if the stock fan could still be used adequately. Better still is the price is around $210.
Any thoughts?
Any thoughts?
