cdncutlass
- Jun 12, 2012
Please excuse the long post,
I have a 200-4R in my Cutlass behind a 408 c.i small block chevy. The transmission has very few miles. It has a monster in a box 200-4R kit with an extreme automatics valve body, and a 2800-3200 converter with lockup.
Everything was working great. My lockup did start acting up. It actually wouldn't engage, but otherwise no issues. So I bought a new lockup solenoid this weekend and was planning to install this week.
Driving down the highway today I decided to hit the lockup switch and to my surprise it was working. Lockup engaged much slower than before but it worked. Then when coming up to some traffic I turned off the switch and lockup stayed on. The car chugged a bit but we started moving again.
Later I got off the highway and was more into city driving. The car wasn't shifting right and I thought maybe the lockup was still engaged. It started shuttering at low speeds which I thought was the converter. It was making a whining noise. Then it seemed as though the car was in neutral just revving and not moving. I pulled over and checked the fluid level.
The fluid was clean not low, and not burnt. Get back in the car and shifting into gear there is no positive engagement like its in neutral again. It would barely move under it's own power. I shut it down and had it towed home.
I will have a chance to drop the pan tomorrow after work. Any ideas what my problem is? Could it be a pump or converter, or is the transmission done? Anything simple I should check for?
