Switched from non LU to Vigilante. What I did was remove tranny, had the pump blue printed and the Vigilante pump kit ( tube ) installed. Reinstalled pump, lu solenoid, and PTE rear pick up for the deep pan. The only changes to the tranny from last year are the Vigilante and pump mod. I don't believe that these changes are the cause, but I'm trying to cover all the bases. After filling the tranny w/fluid, the car will barely move in forward or reverse and it pissed tranny fluid out the fill tube. Feels like the pump is cavitating. Does the pump need to be primed? Should i run the trans on stands before trying to drive it? Any ideas as to what's happening? Thank you! Brian
