B buickboy92 Member Joined Feb 3, 2009 Dec 15, 2009 #1 A transmission cooler out of a ford f150 fits perfect in the core support not sure what year it was out of ill find out
V V8Killer GM speed junkie Joined Nov 22, 2001 Dec 16, 2009 #2 buickboy92 said: A transmission cooler out of a ford f150 fits perfect in the core support not sure what year it was out of ill find out Click to expand... How big is the cooler? What ends for the lines? Got a pic of it?
T turbobob924 Member Joined May 28, 2001 Dec 16, 2009 #3 be very careful using used coolers! When I worked at a remanufactured transmission company, clogged cooler and related trash was one of the biggest reasons for transmission failures. As long as you make sure you run it thru a parts cleaner you should be OK.
B buickboy92 Member Joined Feb 3, 2009 Dec 19, 2009 #4 yea it flows good. ill put a picture on here for you
R "Reaper" Gone To The Dark Side Joined Nov 22, 2007 Dec 22, 2009 #5 buickboy92 said: A transmission cooler out of a ford f150 fits perfect in the core support not sure what year it was out of ill find out Click to expand... Was you able to find out what year? still waiting on pic as well. Thanks Shaun
