Tranny pan torque specs?
BBcallaway
Can someone help me with the tranny pan bolt specs? And if you know the diff bolts specs too. On a stock 87 GN.
- 6 to 10 ft/lbs for the transmission pan bolts
- 22 ft/lbs for the rear axle cover bolts
Sources:
Per the service manual "Section 7 - Transmission/Transaxle" "Figure 132 Torque Specifications"
TRANSMISSION OIL PAN TO CASE - 8.0-14.0 N-m (6-10 ft.-lbs.)
Per the service manual "Section 4B - Rear Axle"
"Cover bolts in a crosswise pattern and tighten to 30 N*m (22 lbs. ft.). "
Also "Rear Axle Specifications - Torque Specifications" on page 4B-24:
Rear Axle Housing Cover to Carrier - 30 Nm - 22 lbs/ft
