F
Famlycar
Guest
First off let me say the tranny is acting up and will be coming out shortly. Last week my IGN Module went bad and I replaced and all was well. I decided to replace the plugs as well. After replacing the plugs and going for a drive I noticed the car seemed to be sputtering some. When I got up to 45mph and the convertor locked it got really bad like the car was jerking. I got back to the house and replaced the wires with a set I had and still had the same problem. I had this problem before and the cause was fouled plugs. Changed the plugs and all was well. The odd thing is that when I was driving today I started to suspect the tranny because it got worst when the convertor locked. I pressed on the brake pedal lightly to unlock the convertor and the jerking/slipping would stop. When I would let off of the brake pedal and the convertor would lock again the jerking would start again. Then press on the brake pedal again to unlock the convertor and the jerking would stop. I'm trying to figure out if its the tranny or an electrical problem. If I mash down on the gas and go under boost there is no sputtering or anything. Car pulls fine. It would seem if the tranny was bad it would act up when I got on it. So what do you guys think? If unlock the convertor around 45mph via the brake pedal it goes away. Once the convertor locks back up it starts again yet if I kick it car pulls fine. Is it electrical or tranny? I'm puzzled. Thanks.
