i have an 87 t typ limited just bought had a frien put in on a dynno a/f came back 10/1 to 14.5/1 he tells me its way to lean and should not drive it am i missing something? boosting about 18 psi
i just bught the car i have limited info it an older build i belive its running the stock pump mas is grannatelli spearco intercooler 36 lb injectors 1.65 rockers garrett turbo dont know the model somesort of mild cam was set up on nos still
have the bottel not plumed 3.73 gear 2800 stall converter im still trying to figure out what i have i dont have a scan tool any sugestions on where to start?
Start with a scantool like a scanmaster.
2.. get a new fuel pump and hotwire kit
3.. work from there..
No flooring the car anymore until you have a scantool hooked up. Unless you want to build a motor sooner than latter.
Fuel pump is a no brainer.
