G garyg New Member Joined Jun 28, 2007 Jan 30, 2008 #1 what are the biggest tire size you can install on both front and rears on a 1987 Turbo regal with the stock t-type rims?
U UNGN Can't Re- Member Joined May 24, 2001 Jan 30, 2008 #2 garyg said: what are the biggest tire size you can install on both front and rears on a 1987 Turbo regal with the stock t-type rims? Click to expand... 275 wide in back, 245 in front. There may be slight rubbing over large bumps or when turning sharply, but they won't rub in a straight line.
U UNGN Can't Re- Member Joined May 24, 2001 Jan 31, 2008 #4 garyg said: is that with spacers or without spacers? Click to expand... That is without spacers.
C charlief1 RIP Charlie! Joined Sep 20, 2007 Jan 31, 2008 #5 UNGN said: 275 wide in back, 245 in front. There may be slight rubbing over large bumps or when turning sharply, but they won't rub in a straight line. Click to expand... What aspect ratio? 60's or 50's.
U UNGN Can't Re- Member Joined May 24, 2001 Jan 31, 2008 #6 charlief1 said: What aspect ratio? 60's or 50's. Click to expand... Both 50 and 60 series tires.
