1987noblegn
- Jul 24, 2011
the motor only has less than a thousand miles after rebuild and already the thrust bearing is shot and one of the mains is mashed and started to wear and crank is grooved. rod bearings look great. looking for any input on what caused a failure already. we took apart motor trying to diaganose low oil pressure problems and found gobs of copper flakes in pan. the tranny is also doing what my tranny guy calls a flare between 2nd and 3rd and beleives it is a pressure problem. ive heard that can cause thrust bearings to go out. can this cause more? hoping to be able to mill the crank again and replace all the bearings but also want to prevent this problem again.
