Thoughts on state of Tune & log files?
zigm
I'm very pleased how well my car is running since I put the new Street 93 TurboTweak chip in! I also just finished spring cleaning... The only open item I know of at the moment is the cracked driver header needing a weld.
My setup is in signature (think cutting edge circa 2001).
Boost built quickly and held rock solid @ 19psi during my WOT test runs tonight. I never saw any knock on the Turbometer Pro log files or the Casper gauge. O2 #'s look good with no sign of leaning out.
I know a Powerlogger would be better, but it's just not in the budget at the moment.
I'm wondering why my Voltage is so low.... I'll check all grounds tomorrow. Coolant reading is bogus, so please ignore.
Should I keep turning up the boost and adding a bit of fuel until I get some knock? 19psi seems awful high to me for a stock longblock (with fresh valve springs) on 93.
* What is the max boost you guys would expect for my combo on 93 octane?
* How much extra % of WOT to add for every additional 1psi of boost? (any rule of thumb?)
Engine @ idle in Park:
Time(s) 1.25 2.5 3.75 5 6.25
IAC 8 8 8 8 7
Coolant(F) 248 248 248 248 248
MPH 0 0 0 0 0
RPM 800 800 775 775 825
Load 35 36 37 37 34
TPS(V) 0.45 0.45 0.45 0.45 0.45
BLM 120 120 120 120 120
Integrator 128 128 128 128 128
O2 (V) 0.82 0.82 0.812 0.816 0.816
O2 Xovers 83 83 83 83 83
MAF 5 5 5 5 5
Retard(deg) 0 0 0 0 0
Batt(V) 13 13 13 13 13
MAT(F) 127 127 127 127 127
ESC 0 0 0 0 0
EGRDuty(%) 0 0 0 0 0
TCC Off Off Off Off Off
Loop Open Open Open Open Open
3rdGearSw Off Off Off Off Off
4thGearSw Off Off Off Off Off
Accel.(G) 0 0 0 0 0
WOT test 1 from a 50mph roll:
Time(s) 7.5 8.75 10 11.25 12.5 13.75
IAC 78 78 78 78 78 68
MPH 49 58 70 80 88 96
RPM 3225 4975 4550 4750 4900 5050
Load 193 255 255 255 255 255
TPS(V) 4.21 4.39 4.68 4.68 4.68 4.68
BLM 128 128 128 128 128 116
Integrator 128 128 128 128 128 128
O2 (V) 0.789 0.804 0.769 0.761 0.761 0.761
O2 Xovers 1 1 1 1 1 1
MAF 239 255 255 255 255 7
Retard(deg) 0 0 0 0 0 0
Batt(V) 12.7 12.8 12.6 12.6 12.7 12.6
MAT(F) 117 120 121 120 120 125
ESC 0 0 0 0 0 0
EGRDuty(%) 0 0 0 0 0 0
TCC Off Off Off Off Off Off
Loop Closed Closed Closed Closed Closed Closed
3rdGearSw Off Off On On On On
4thGearSw Off Off Off Off Off Off
Accel.(G) -0.04 0.33 0.44 0.36 0.29 0.29
WOT test 2 from 50mph roll:
Time(s) 8.75 10 11.25 12.5 13.75 15
IAC 78 78 78 78 78 78
Coolant(F) 251 251 251 250 251 251
MPH 47 61 73 82 91 98
RPM 4475 5100 4600 4775 4925 5050
Load 255 255 255 255 255 255
TPS(V) 4.51 4.68 4.68 4.68 4.68 4.68
BLM 128 128 128 128 128 128
O2 (V) 0.793 0.793 0.765 0.765 0.761 0.765
O2 Xovers 67 67 67 67 67 67
MAF 255 255 255 255 255 255
Batt(V) 13 12.6 12.7 12.6 12.7 12.6
MAT(F) 120 122 125 126 125 124
ESC 0 0 0 0 0 0
3rdGearSw Off On On On On On
Accel.(G) 0.07 0.51 0.44 0.33 0.33 0.26
The only thing that jumps out at me is your coolant temp is WAY too high. Check the sensor.
And like you said, your voltage is pretty low.
TPS is a little lower than it should be.
760 o2 count is a little leaner than I personally like to run but you're probably fine on that.
Yeah.... probably right on the edge... so perfect! :biggrin: Doubt you are going to be able to run much more boost w/o detonation, but will definitely need to add fuel as you add boost. TPS is fine there. Volts are pretty typical. Mine dips into the 12's most of the time too. These cars suck alot of juice at full boogie... Numbers look great... :cool:
Thanks for the feedback...
Let's say I leave the boost where it is @ 19psi. If I'm getting absolutely no knock now, what would happen if I raised timing a degree or two? (Better spool, snappier throttle response?)
Would that change O2 readings, and also require more fuel?
How much could I expect to push the envelope with timing?
The TT chip is labeled as 17-18psi, 20/18 deg.
what version of turbometer do you have? and was that coolant reading close to correct ? I had read that turbometer had an issue interpreting the coolant signal and would show the temps way off.
