GetOwnedVette
- Jun 13, 2006
If you're looking for total "seal", go with the RJC's, the Cometics tend to act like a fuse and blow before the pistons, rods, or bearings let loose.
Isnt that the point?
Yup pretty nasty.
The point I was trying to make is that the Cometics will seal the heads!! The issue with my motor was a boost controller that decided that i was not running enough boost, so it corrected it for me !! My fast saw 29.6 psi which is all it can see with a 3 bar map. I have no idea how high the boost actually went. It was a pretty violent event, tires spun on the street and I pedaled it and hit it again. My boost was rock steady at 22psi in NC. I only made 4 passes up there as I was having problems pushing through the lights with 0 boost. My car went 6.93 @103 with a 1.54 60', 0 boost launch at 22psi and 21* on pump gas and ALKY. The car is making good power, 555 HP 553 TQ. Blew out a wheel cylinder and had to go back to RC's shop so I could fix the brakes and tune the car on C16.It rained and I never got the C16 tune which may have saved the motor, who knows. The boost controller is coming off and I will be installing a solenoid connected to the FAST for boost control.
Bryan
I am undecided on the head gasket choice as of now. I want to run 30 psi but dont want another meltdown
Bryan
Got mine from CottonsSo i can't go wrong at all. A set if RJC are $140 and the Cometic is 180 Right or wrong. What the best place to get the Cometicfrom?
Bryan
The best gaskets are RJC and Cometics. I say both are being used with great success. Or so I read. Bryan what boost controller are you going to use?
I just want to say thank you guys for all of your help. I'm all most ready to get me stroker motor started. Then getting parts little be little so It's time to take it to the shop. I have to start think about what kind of turbo now to get? Any input on that?
The t70 you have isn't big enough? You're going to need more injector too...
