Re: Art
Originally posted by Wht87T
One of the first things I told cal was that it was going to be street driven. He knows that and I'm sure he's taken it into consideration. Yes a built 200 with OD would be nice but I'll be wasting my money. Both orlando and the track are an hr away from here, but thats the price I'm gonna have to pay. Like my old man said "if you wanna go fast ur gonna pay the price"
What happened to the 3.42s out back? I still have the stock rear and a 26" tall tire for the street. A loose converter might not be that bad afterall. I should start savin the rest of my pennies and buy a beater like every other college student has. lol And its getting a billet roller but not with humongous lift. Its all give and take I've allready made some compromises.
Rich
You're right I'll probabally have to bring a change of underwear to the track. I've got some pics of the newly installed 6-pt I'll send you some pics.
Thanks for all the info guys!
Yes John, of course it's getting a billet roller, don't want a fiasco like the non-billet debacle again. With a billet roller cam you have very aggressive ramp up speeds and a hardened (billet) cam to handle it. To handle these ramp angles you need a roller lifter. You have a choice of going with either a hydraulic lifter or a solid lifter (just like with a non roller cam). A solid lifter needs to have the lash checked frequently like any other solid lifter. If you have a hydraulic lifter you don't need to check as often if ever at all. A hydraulic lifter is also going to take up some of the pounding on the valve train as the cam ramps up (it’ll compress a little to take up the shock). With a solid lifter the valve train is put under a lot of stress because the cam isn't going to give so the lifter, pushrod, rocker and valve are opened very quickly. This is great cause the faster you open the valve the more fuel you can get into the combustion chamber. The trade off is a lot of stress and wear. I think most people that are going to drive their car on the street go with a hydraulic lifter. I'm not sure but I'd imagine you're probably limited to about .600-lift with a hydraulic but that's just a guess on my part. Smarter people than me would know for sure. I do know with really high lifts comes higher spring pressures and a hydraulic lifter will end up bottoming out so you'd have to go with a solid lifter.
It depends on the distance and route to the track. If it's all highways at 60 MPH then that's a lot of stress an hour each way. I usually try not to take my car above 50 MPH and the 25 miles takes me about 40-45 mines to get to the track as only about half is on Rt. 1 and Rt. 18. Believe me, it's a lot of wear and tear.
If you are only going to run 26" tires then it's fine. Even 28's are OK depending on which guru you ask. I run a 29.5" slick. In a stage car with 30" slicks I should probably have 3.90's minimum but like I said, I drive to the track so having 3.73's and 28" tires works well. If I stepped up to the 3.90's or 4.10's then I'd really be putting a lot of stress on the motor on the highway. Also, it's a combination. I run a T-76 turbo so with my combination max HP is about 5850 on the dyno so I need less gear otherwise I'm revving it way past the limit of the motor. It's also a reliability thing, less RPM's on the motor, less boost, etc. longer life. I'm shifting about 6200 RPM's and going through the traps at about the same so the combination works well at the 20 or so psi of boost I run depending on the weather.
I'm sure Cal is going to replace the stock posi with an Eaton or something. Probably girdle it too, would be a smart move. If you are going to continue to run the 26" tires then stick with the stock gearing. If you are going to step up to a larger tire to get a longer footprint and more traction then you may consider 3.73's. It all depends on your combination. No one can make a decision without knowing the total package. You know, great cam, crappy heads and the combo doesn't work, stuff like that.
Loose converter is a relative thing. You'll probably be going with a 3000-3500 stall converter. I doubt you'd need more than that. Depends on where you are revving the motor to and where the power band of the motor will be. Again, all combination.
You're dad is a wise man, that's why I like him!
