Th400 short or long?
etriebe
Which one should I use to get the same length as a 200
Could I buy a 400 with a long output and put a short one in?
So the shaft I need is 7"
I have a Quatermaster aluminum one already and was hoping to use and just replace the front yoke
We have seen up to 1" difference driveshaft length in various GN's when it comes to a trans/driveshaft replacement, so it should be measured like Paul stated.
If you are installing a TH400 for track use, it would be smart to replace the u-joints with the 1350 series or you will have a time bomb waiting to go off! :)
I learned this the hard way years ago after I spit out the D/S on the track twice. :(
If you do not have enough torque or traction or balls in your car, dis-reguard my comments above.;)
