te45a
shawnz
Is 60 lb inj to small for a te45a also the 9x 11 converter only stalls around 2800 to 3000.Should i downsize thanks
Depends on your cam, heads, exhaust, and tune. I've run the same TE45a on a few combos over the years since 2004. The 45a comes alive at 22-28 psi of boost with ported irons and some cam. I ran 127 mph traps on 48# injectors with the base fueling at 51 psi back in the day.
depends on how hard you will run the turbo,for all in race gas,you would need higher pressure,and more volts to pumps,or you could just do a single nozzle meth kit and be done.the stall on the 9/11 isnt high enough for a 45a also
thanks kinda figured was not enough stall
