this has been going on for quite some time now...my torque converter used to lock up at 55 mph with the stock chip and my aftermarket speedo a long time ago...ever since i went to aftermarket chips i haven't seen the torque converter lock up ever...i have even tried to manually lock it via splicing a toggle switch into the top left ALDL port wire...still no dice...
back in the day i used to be able to feel a slight shift and drop in rpms at around 45mph which was indicating the tcc was locking up...i would hit the brake and rpms would jump up and such...now the car hits 4th gear at 35mph normal driving and there is no more slight tug and drop in rpms at 45mph....i used to be able to cruise at 65 mph at around 2200 rpms...now it's close to 2400-2600
i have had turbolink hooked up to verify the lockup and nothing...i know that these cars have some sort of TCC solenoid underneath somewhere...could that be what is bad? will that cause the TCC not to ever lock up? i would really like to be able to lock it up by this friday...i know it's worth 2 tenths just by locking it...any help is much appreciated
