Previously my TTA with a TA49 and 36# fuel injectors ran a best of 11.79 @ 114.7 with a 60' of 1.61. Usually the car ran in the 12.0’s to 11.90's. In my quest to better my ET and MPH I purchased a PT61 turbo with 60# injectors. The following are the mods to my TTA:
Extender Chip - 23/19 timing
MAF Translator Plus
PT61 P-Trim Turbo
60# Mototroininjectors
Walbro 340 Fuel Pump
Action Fab 3” downpipe
freeflowing exhaust with testpipe
62mm throttle body
ported plenum
1" plenum spacer
adj fuel pressure regulator
ATR bleed valve to control boost
PTS 9/11 Torque Converter (Advertised 2800 stall)
LT1 MAF Sensor
Translator Plus
K&N 8" Air Filter on 3" Stainless Steel MAF pipe
110# valve springs
BFG Drag Radials on the stock rims
Spohn Adjustable Torque Arm
Global West Subframe Connectors
Spohn Adj Panhard Rod
Spohn Lower Control Arms
On the street I run 92 Chevron unleaded premium
At the strip I run Sunoco NOS Supreme Racing Fuel (117 octane)
Turbo Link 4.0 used as my data logger
I have run the car twice with the PT61 and have lackluster results. The first time was with the ULTRA Chip and it was running very rich. It ran 12.40 to 12.50 at 113 mph with 60’ time in the 2.0’s. The car was running very rich so I purchased an Extender chip along with a MAF Translator Plus so that I can adjust the A/F ratio and ignition timing. I went to the track yesterday 6/26/05 it was equally unimpressive.
I was only able to turn a 12.50-60 at 113-114 with my short times in the 2.0-2.1's. I can understand the poor short times are attributable to the stall speed of the torque converter (2900 rpm) and that I need the stall to be 3400-3500 to properly spool the turbo, but the mph with this turbo should be in the 120 mph range. My boost was set at 22-24 psi and the O2 volts were in the 790's the end of the quartermile, so I feel that it may be a little on the rich side of the fuel curve. The T-Plus was set for 2 percent rich for the base fueling (this was done to get the cruise BLM’s close to 128) with no changed for WOT and 4 degrees retarded for the base spark with no change for WOT.
With the smaller 800CFM TA 49 the car was consistently producing low twelve/high eleven second time slips with a Caspers Ultrachip with the #4 chip selected (20 degrees of timing at WOT). I don't understand what is holding the engine from developing the horspower that the PT61 (900CFM and 600HP max horsepower) can generate. I am perplexed...any ideas on what is wrong would be most welcome.
MAF Translator Plus
PT61 P-Trim Turbo
62mm throttle body
ported plenum
1" plenum spacer
LT1 MAF Sensor
Translator Plus
110# valve springs
