My combo is in my sig. For the mid-11's at 119 mph runs, I was around 25 psi boost and pretty much had the TA49 maxed out. I've run both the stock Garrett .63 housing and the Precision .85 housing. The Precision .85 housing definitely helped the top end, maybe worth a mph or two in trap speed. I don't think I could have gotten to 119 mph with the Garrett .63 housing. With both my restalled D5 converter (about 2800 stall) and my Mike Ridings converter (similar stall), I have absolutely no problem spooling it up.
If you're going to be spending a lot of time at the higher boost (like 25 psi) and care about the highest mph at the track, might be worth a look. If you're going to be spending most of your time at lower boost (23 psi or lower), you could probably find better things on which to spend your money.
Good Luck,
Mike
Sent from my HTC Droid Incredible using Turbo Buick
