TA S2 offcenter longblock
-3.625 billet crank
-billet crower rods
-JE pistons
-champion gn1r heads
-Jessel rocker arms
-solid roller cam
-champion intake
-hemco plenum
-70mm accufab t/b
-aluminum deep oil pan
-duitweiller type oil pump with filter relocation and lines
-h&r motor mounts
-high torque mini starter
-underdrive crank pulley
DOES NOT COME WITH WATER PUMP OR PULLEY
Motor has about 25 passed on it and most of them were under 20psi. It made 740rwhp at 18psi with an 81mm turbo, with dyno sheet.. It also went 9.7 @ 143 with a 88mm turbo at 16-17 psi in a 3550lb car. Motor was built by TA Performance and I do have all the build records with measurements, clearances ect... EXTRAS I have new 160lb white top inj, billet fuel rails, aero motive regulator and 200 amp alternator that could be worked into deal.
13k PLUS SHIPPING for the longblock not including the extras
-3.625 billet crank
-billet crower rods
-JE pistons
-Jessel rocker arms
-solid roller cam
-champion intake
-hemco plenum
-70mm accufab t/b
-h&r motor mounts
