TA Performance "competition header"
slowboi
Header can be seen here:
http://www.taperformance.com/proddetail.asp?prod=TA_V2010CH-SS
Im parting out my T-type and I have TA's high end turbo header for sale used. "Jet hot" coating is scratched up a bit. The header however is in good shape. I had no exhaust leaks out of this thing as the fastening system is really great. Big double slip fit crossover. Three bolt version.
This header is 1050$ from TA plus shipping. Im looking for $700 OBO.
Could I get some pics of port size? Have a stock header to compare it to? Interested
I don't have a stock header handy. I measured the runners at slightly over 1.5 inch (exterior) The ports are larger in area than that as they are square. Ta did a good job with the transition as its fairly smooth. If you wanted to sit there and gasket match/blend each port there is plenty of material on the flange to do so. These headers took my car to mid 10's as they sit. Best of all they didn't crack or leak.
The crossover looks like stainless to me, the headers are coated so I cant say 100% .... is there a way to check?
