Originally posted by EFFNQWKWE4
I've had my car for about 9 months now, and I'm finally getting to all of the little tips and tricks. Yesterday I was going to adjust the TV cable a click or two, (never done this before) and I noticed that it's already backed all the way out! The previous owner must have adjusted it before the car was sold to me. My question is this- how do I get my 2nd gear "chirp" back?
In order for a "chirp" to happen you must A) have the power and B) have a quickly shifting transmission that allows the tires to "turn over" at the shifts.
You seem to be focused on B) and not A). Are you certain of the culprit?
The car stopped shifting hard a while ago. Used to spin at the top of first, the chirp HARD into 2nd.....now, no wheelspin, no chirp. I have identified that the clutch pack in my posi needs to be replaced. Could this be the reason that my car isn't performing/shifting like it should?
The clutch pack in the posi has
nothing do to with A) or B) above.
Or, should I start looking at trans parts?
IF you are certain that this isn't a motor-power-related issue, then yes.
I read that if the TV cable is adjusted on a car with an ailing trans, it will speed the wear on the trans.[that's correct! What damage may have occurred to my drivetrain by driving like this, and more importantly, how do I fix it? I can't just re-set the cable, can I?
The damage is smoked clutches and/or a burned band. If the cable is already pulled all the way out, it is stretched out of shape, not allowing it to do its function. The function of the T.V. cable is to raise the tranny fluid line pressure as you go deeper into the throttle.
It is a likely scenario that the trans was starting to fail prior to your purchase. The previous owner then tightened up the T.V. cable to increase the line pressure to literally "force" the transmission to shift hard. But when too much line pressure is used ALL the time, the clutches and the band wear out more quickly.
You "fix it" by rebuilding the trans with fresh clutches and a new band (for starters). Note, if you just replace the T.V. cable to up the line pressure again, you will succeed in having the clutches and/or the band
completely burn away all friction material left...causing major schrapnel damage to go through your transmission.
BUT, IF the trans is working fine and the motor just isn't pumping out the ponies anymore, you've just thrown away several hundred dollars on an uneccesary transmission rebuild.
