Exactly what CHARGED and UNDER-PRESSURE have said.
The best thing you can do for a T-Top car, or for that matter any Turbo Buick that's making some power and no roll bar, would be to order Kirbans braces.
Front frame braces, Under hood braces, rear seat brace kit, connecting front frame brace, and his 6 piece lower body bushing kit. It's a proven fact that 9 out of 10 cars that rolled off the assembly line were missing at least 2 lower body bushings. GM got cheap on us towards the end of production for the Regals.
These parts will significantly tighten up all of the versions, especially a T-Top car. On my old grey car, I ran it into the 10's for 4 years without a roll bar (I know not smart, but I was young and stupid then) but with all of these braces and it always left straight without any twisting. Not even any cracked paint on the C pillar. Given it was a hard top car, but it proved that these braces worked. I have seen numerous T-Top cars run into the 10's without roll bars but just bracing, as well as into the 9's with roll bars/cages. I am currently installing all of these parts on my new T as we speak. The bushing are very easy to install, only takes about 30 minutes if you take your time, and all you need is a 15mm 1/2" drive socket, 6-10" extension, and a 1/2" drive ratchet. The front frame braces and connecting brace utilize exisitng holes that are already on the car. The rear seat brace kit does require that you drill the holes, but it's really not that big a deal, and the under hood braces only require two holes drilled. It's best to take out your battery when you drill the hole on the passengers side inner fender so that you can vacuum all the shavings out and get a drill at the hole easier. I highly recommend these parts for every Turbo Buick, no matter the year or level of modification. They all work together to significantly tighten up the chassis.
Here are the parts we are referring too.
Front frame braces #6564
Underhood brace kit #6744
Rear seat frame brace kit #1586
Connecting front brace #6746, goes underneath the radiator and ties into the front frame braces forming a triangle. Won't work with front mount intercooler whose pipes go underneath the radiator support.
Six piece lower body bushing kit #6737
Hope this helps.
Patrick
