Swapping a 1997 Bonneville L67 into a 1988 Park Ave...
Darth Fiero
3800 Series II Turbo
A friend of mine approached me and asked me to do him this swap since he knows I do them for Fieros and other vehicles. I kinda questioned his motives about wanting to swap this engine into his 88 Park Ave but he lives in a not-so-great neighboorhood and doesn't want a nice shiney new car because he won't be able to keep it long. Anyway, he found the complete 3800SC/4T65-EHD out of a wreaked 1997 Bonneville SSEi and had me go pick it up.
Transferring from H-body to H-body seems to be easy enough but there are a few small differences between 1988 and 1997, besides the wiring and computer.
I have already started this swap and gotten the old powertrain out (3800 vin C / 440-T4) and got the 97 powertrain bolted to the cradle. As far as mounting, the major difference is the right-rear transmission mount that comes on the 440-T4 will NOT bolt up to the 4T65-E. However, the H-body 4T65-E does come with a mount in that location but it is a dog-bone. What I did was take some measurements and cut off part of the dog bone bracket and welded a plate onto it at the proper angle so I could re-use the 88 Pk Ave's factory hydraulic mount in that location. The front right engine mount was easy enough it was part of the A/C bracket on the 3800 vin C. This bracket will bolt up to the L67 but you will have to do some cutting and grinding so it will fit properly. There were two main problem areas: The deck height of the Series II engine is shorter than the Series I which means there is not as much flat area above the 3-main bolt holes for the front A/C mount. Also, the H-body L67's SC idler pulley bracket occupies some space by where the old A/C bracket wants to sit so you will have to grind a little there. Best thing I can tell you to do is get a silver permanent marker and do some mock-up mounting and cut/grind a little at a time until it sits flat. It just so happens this car just had the A/C redone not to long ago so I didn't want to change out the compressor so I could use a different bracket. Its on and works fine no problem.
The other two trans mounts bolt right up, you can use either the 440-T4 or the 4T65-E mounts from the Bonneville. I used the front left trans mount from the bonne because it had that mini-shock absorber on it to help limit the movement of the engine. The rear left mounts are virtually identical.
Appearantly there is no difference between 88 and 97 steering racks pertaining to how the P/S pump lines hook to them because the 97 P/S pump and lines from the Bonneville bolt right up perfectly.
As far as exhaust, anyone who is familiar with these cars knows you have a lot of room to work with so it looks like I will have no problem building the 3" mandrel bent system my friend requested.
Heater hoses will need to be replaced but again I have some room to work with so no worries. The cooling systems are very similar so the hoses from the 97 should work fine.
Tomorrow I start on wiring the 97 PCM into the car. This should be fun!
Sounds cool :cool: and should make a nice sleeper! Keep us posted..:D
BTW, what's the average price range for a Series II SC motor these days...I have a '91 NA Regal that might like one.:)
I just talked to a guy the other day that picked up a 2002 GTP L67, tranny, PCM and wiring, 20,000 miles for about $1800.
ran into the first big snag today. the park avenue's original A/C compressor interferes with the SC belt ever so slightly. I measured up the 97 bonne compressor and it would interfere too if I could bolt it to the park ave bracket, but the leg spacing is wrong. Appearantly the L67's A/C bracket moves the A/C comp out away from the block by an inch or so compared to this one. So my solution was to unbolt the A/C comp top bolt, move it out about 2" or so and use a steel plate to connect it to the bracket. Easy enough it is pleanty strong and I can retain the park ave a/c bracket and comp. I can't use the L67 A/C bracket because it has no provisions for a mount in that location. The 96-up L67's that came in the H-body cars used a funky central mount that sat over the water pump and connected to the body frame rail. This type of mount is dumb in my opinion because it makes changing the serp belt a pain but hey I guess its better for isolation of vibrations. Here is a pic of what I did for the A/C comp: http://home.att.net/~darthfiero/ACcomp.jpg
Aside from the A/C issue, the factory metal fuel lines for the park ave came right up beside the EGR valve, which is where I cut them off and connected them via fuel injection hose to the fuel rail on the L67. Shift cable and bracket bolted right up no problem.
http://home.att.net/~darthfiero/L67engine1.jpg
Here are some other pics:
http://home.att.net/~darthfiero/ltL67engine1.jpg
http://home.att.net/~darthfiero/rtL67engine1.jpg
Here is what I built for the right rear trans mount:
http://home.att.net/~darthfiero/rttransmount.jpg
That's great! I have wondered about those types of swaps for a while. My idea would be to put the SC3800 in a 92 Olds Toronado Trofeo or my son's 93 Cutlass LS. Wish I had the time, money and knowlege to do stuff like you do. Keep informing us on your projects they're cool.
Got the PCM mounted and layed the wiring on the engine today and started plugging stuff in. The major part of the wiring is going to be limited to where the stock bulkhead connector was for the 3800 vin C harness. In this location, the L67 harness has a bulkhead connector C101 in which all of the wiring for the fans, fuel pump, gauges, etc passes thru. I am going to use the 88's stock bulkhead assy and some of the wiring too and splice both harnesses together. Inside the car by where the 3800 vin C's ECM used to be located, there is a large grey connector where the ECM mated to the vehicle harness. I have to make use of this so everything works correctly.
Anyway, here is a pic of how I mounted the PCM. Notice I relocated the air-ride suspension pump to the side of the frame rail, and the L67 PCM now sits where that pump was.
http://home.att.net/~darthfiero/PCM1.jpg
I also removed the stock EVAP canister so I could run the cold air induction outside of the engine compartment and mount the K&N air filter behind the bumper/fender. I have the OBDII-compliant EVAP canister from the 97 Bonne and I will need to find a place for that but I don't think it will be difficult.
http://home.att.net/~darthfiero/PCM2.jpg
ok time for a little update...
Had to replace the front struts on this vehicle so that was a non-swap related issue. I did run into a slight problem with the CV axles. As you may or may not know, the 4T65-E HD uses larger inboard CV axle tripods and spline sizes which means the original ones from this car would not work. Besides that, the outer CV tripod ends had the wrong spline for this car as well. To compond things further, disassembly of the HD and 88 Park Ave axles reveiled that the HD inner axle shafts have larger spline diameters where they connect to the CV tripod ends. This means I could not simply insert the HD alxe into the pk ave outer tripod end. BUT the good news is BOTH the HD and 88 pk ave outer tripod ends used the same ball bearings and cages which means all you have to do is pull all the ball bearings out then you can remove the inner race that contains the axle. Instructions on how to do this can be downloaded here: http://home.att.net/~darthfiero/CVouterRepair.zip
I also had a chance to fire it up today. It runs pretty good but I still need to finish the exhaust and replace the fuel pump with a Walbro 307.
I will post some pics of the 3" mandrel bent exhaust system I am working on tomorrow.
Wrapped up the 3" mandrel bent exhaust system today. I used the stock 97 Bonneville cat but removed the double-wall exhaust tubing that it had going to it. After you clean up the inlet and outlet it is almost 3" ID, so I figured it would be good enough for this engine. Since I removed the stock flex joint, I replaced it with a universal 3" flex joint I got from NAPA. Here are some pics.
http://home.att.net/~darthfiero/ParkAveExhaust1.jpg
http://home.att.net/~darthfiero/ParkAveExhaust2.jpg
I also replaced the factory pump with a walbro 307.
http://home.att.net/~darthfiero/ParkAveFuelPump.jpg
The factory fuel pump was a massive unit with a noise suppressor on the positive lead. All that went bye-bye when I installed the 307.
Hooked up the cruise control and it is just about done. All I have to do is recharge the A/C and change the oil.
http://home.att.net/~darthfiero/L67complete.jpg
Originally posted by 4timesT
What's a conversion like that cost? Not including the donor parts.
Thanks.
Well as far as parts this engine had just about every gasket leaking so I replaced them all before the install. He had about $200 wrapped up into the gaskets, hoses, and belts. Exhaust system was approx another $150 minus muffler. Figure in another $50 for shop supplies and fluids which brings the parts total to about $400, again not counting donor parts.
Now for this kind of swap I charge $1250 labor and up depending on what all you want done. Obviously if you need other repairs done or mods performed to the engine/trans before installation the cost will be more. What my base labor charge of $1250.00 covers is the following:
-Engine/trans inspection and cleaning
-Removal of old powertrain
-Installation of new powertrain
-Fabrication of mount(s)
-Fabrication of exhaust and induction
-Modification of wiring harness
-Modification of CV axles (if using stock parts)
-Vehicle testing, inspection, and basic maintenance (fluid changes) before delivery
Good price for such great work. Can it be done to a 1994 Buick Century wagon? I had one, but it got slammed in an accident, but I'm looking for another 1.
The Buick Century platform is a slightly smaller body/engine bay to work in which may require more fabriction/modification, but I don't see why it wouldn't work. I did get a Series I 3800 to fit down in the small engine compartment of my 88 Grand Am so anything is possible.
