Mountain GN
No, it doesn't have a V8.
- Apr 19, 2006
Installed a 160 t-stat and a Kirban's stainless steel housing. After making sure the thermostat was in straight, I put in the new housing, but it doesn't sit flush with the intake, but sits out a bit. When I put the retainer on it, it holds it the housing in firmly, but I can tell that it's angled a bit.
After trying this a few a times, with the same result, I called it good and hooked everything back up and it filled with coolant. So far, after running it for about 20 minutes and taking a quick drive, there are no leaks.
Still, I'm not comfortable with this and am wondering if I should take it apart again, or this the normal fitment of the Kirban's housing?
