turbofabricator
- Mar 7, 2004
I had the exact same deal happen when I started can On-Center Stage II street combo many years ago. I had to shim the lower crank pulley with washers to get proper alignment. I didn't have studs the right length, so I used bolts and ended up dropping one set of washers and didn't notice it. It started whipping the belt and it sounded like a ball peen hammer hitting the block. Not like a rod knock, more randomly similar to your friends. Definitely a belt issue.
