Thanks guys.
I guess it comes down to how good the stock injectors are? What is a good method of cleaning them? Soaking them in carb cleaner or brake cleaner? Car has an heated O2 sensor, scanmaster, digital knock sensor, adjustable fuel pressure regulator, etc. So i would be able to monitor lean / rich conditions.
With the Alky kit, do you need a specific chip program or can you just increase boost pressure and check for knock? I think 91 octane (easier to get), 22lbs boost, alky kit and RJC power plate should be ok? Any comments on this set-up?
