Stock bolt on GN 11.46
trashmechlv
87 GN with unopened longblock besides Comp 980 springs.
E85 with 80lb inj
430lph fuel pump
TA52 turbo and ATR headers, 3" DP.
TT 6.1
CAS V4 SLIC
PTC 9.5
11.46 @115
DA 4450 air temp 90 degrees. I think it has a little more in it.
E85 with 80lb inj
430lph fuel pump
TT 6.1
CAS V4 SLIC
PTC 9.5
11.46 @115
NICE!(y)
What have you done w/ the suspension, tires, etc?
NICE!(y)
It has a Hellwig rear swaybar on firmest setting, cheap blue monroe shocks all the way around and Hoosier DOT Drag radials 275/60/15. Front swaybar removed. Thanks! Also was at about 25lb boost creeping to 27lb at the traps
Need more boost... I'm sure its got more in it. Do you know what your injector duty cycle was?
Regards,
Shev
I wouldnt put too much faith in those idc numbers, I just went 130mph on 83lbs injectors with e85, and it was rich.
