Bob, Few things that come to mind.....
1) The TA49 is not going to spool as fast as the stocker (w/ the D5) unless you want to step up a little w/ a slight higher stall convertor...
period. As is...you should be pleased w/ good results & real close to stock spool up. Step up a little & it will out spool the stock turbo. (Before you go that route, I really think there is some tuning needed) I use to run the same turbo (w/ Garrett exh housing) w/ a non-lock up AC 3200, I could smoke drag radials from a dead stop, not braking, by just flooring it. I did have more stall than needed but it sure was fun. At 1st I ran the 49 w/ the D5 and was please but a sale was ran on AC convertors and that was the only reason I swapped out..Sure was glad I did.
2) I don't see a different boost controller helping any. The one above looks very nice & clean. Also like the way it adjust. I may even add one myself.....
but it's not going to change the way it spools. I've used many styles over the years.
3) we need to make sure you do not have an exhaust leak. Try this....
http://www.turbobuick.com/forums/general-turbo-buick-tech/312356-exhaust-header-leak-tester.html
I know it's a low mile car but I also know that the driver's side header is still virgin and at some point they ALL Crack. Need to double verify it's not cracked or you have a pre turbo exhaust leak.
4) Also we need to test fuel pressure to see where you are at. You may be a little rich, causing slow spool.
5) I don't know so I'm asking...What kind of timing is in your chip 1st & 2nd gear? Is it an alky chip or a street chip? Does it have as much timing as the stock chip?
6) Where is the alky coming on at, again could be a rich condition?
7) Do you notice a big difference in
spool up from the blk car to the gray car? Should be real close, w/ a slight edge to blk car.
8)Even if all tuning is dead nuts on...I still think you would be much happier w/ a little more stall.
It will not hurt anyway the car drives, as a matter of fact you'd be doing this :biggrin:
:biggrin: (You'll never notice a difference, except for spool up) If I can talk you in to stepping up to a little higher stall,
nail down the tuning before adding a new convertor. Don't try to fix it by adding parts.
9) I need to drive both cars for a base line.
Which car are you planning on driving in March?
