Figured I start a new thread, last one got a little hi jacked. The last I posted I received my replacement booster and it was better than before but had a problem with air in the p/s side of the system. The stopping power was not that good, the steering was jerky ESPECIALLY when steering and braking at the same time. Old post for refresher if needed http://www.turbobuick.com/forums/br...322931-hydroboost-conversion-got-problem.html.
I had tried different tee locations, length of hose, etc but always had to keep purging air after a short driving time. The condition was returning faster each time with worse symptoms. It got so bad I could not make it out of the parking lot noise was bad, steering and brakes horrible. Figured it had to be the pump going bad.
Ordered an AC Delco reman from my supplier, took a week. It came with paint flaking off, someone needs to learn how to prep before spraying .
Any how, p/s system seems to now be quiet with just a light touch of noise under load (no different than before conversion). Steering feels normal, except harder braking and steering at same time. Steering tightens up until I release the brake. I cannot get the brakes to lock up either, feels like semi-soft pedal. Reminds be of air in the brake system, or like the front brakes are not applying enough.
I re-bled the master cylinder and brake system tonight. It may be a tad better, might be in my head too. Either way, its not right. Braking when turning is an issue, light to moderate braking seems ok both stopping and turning. Hard braking, such as a panic stop only brings you to a moderate stopping rate...not a quick/hard stop. The pedal now feels like it has a click to it, kind of, but not the same, as my first issue with the pedal not coming back up. Hard to describe it. This was not there before tonight. Tonight I did the bleeding of master cylinder & lines, and took the master cylinder from the booster to check for fluid. Nothing much to mention, there was a small dampness but as much ps & brake fluid I spilled in the area, I am thinking no leaks.
I am not sure if I have one problem, such as a booster issue...or compounded problems. I am looking for suggestions to push me in a direction. The loss of steering when braking suggests to ME to replace the booster again. I am open to all suggestions. Thanks.
