DougsfastZ
4.1
- Jan 30, 2004
I've lost a few wastegate vacuum lines in the past and needed a solution. I was swapping out my old GN1 wastegate and manual boost controller for a JGS 400R and boost solenoid for my new ISAC boost.meth controller. Originally I was going to go with 1/4" push-to-connect to match my fuel pressure regulator, MAP sensor and Hobbs switch vacuum lines. In talking with Lance at JGS, we came to the conclusion that the push-to-connect PTFE tube wouldn't hold up to the heat that is near a wastegate so I decided to use hard line.
I picked up several feet of 1/4" steel tube (brake line at the auto parts store) and 1/4" compression to 1/8" NPT fittings. The picture below is how it turned out. I'm very happy with the results and look to test it next week.
