JDSfastGN
- Jun 16, 2001
Well I installed my tranny today and after running around and putting about 6 miles on it or so, it started acting a little weird, it starts off in second almost everytime unless I drop it into manual low, and my 2-3 was awesome and then all of a sudden I have no 2-3 shift any more, it just revs and downshiftsback to second. Its late and I don't have a lot of info like line pressure as of right now. The tranny shifted fine before it twisted an input shaft and OD clutch unit before the current rebuld. Other than the hard parts to replace those, the only other change was from a superservo to a 3sp 200 servo. Does this sound like the band is clearenced too tight, there was no way to shim the servo but it seemed pretty close. Or is this another problem , or do I have multiple problems that came up at the same time? It shifted great for about 5 miles or so, really firm and can chirp 2nd and third at part throttle. 3rd was there and then all of a sudden it was gone. Also reverse does not have a clunk like most do, it just kinda goes into reverse. But drive jolts pretty good. Here is a little info on the tranny, it has an Art carr shift kit, 200 3spd servo, a PTS pump and every billet internal piece available as of now, alto band, and a 2800 stall 12" lu convertor. Any help would be greatly appreciated thanks.
