I read so much about issues regarding coolant seeping up through bolt holes that I'm starting to worry... Just had the engine rebuilt and am finishing up reassembly. I just don't want to have to deal with crazy issues like this when it's finally back in the car and I try to start 'er up.
Is there a rule regarding how much sealant you're supposed to slop onto the threads? I didn't use an excessive amount, but enough to cover them, leaving the first couple threads exposed as suggested. This is basically a stock rebuild... I used FelPro 1000 gaskets and ARP bolts (not the studs). Torqued 'em down, then re-torqued the next day.
I'm sure there are as many opinions on this as there are stars in the sky, but this is the stuff I used:
Permatex® High Temperature Thread Sealant
OEM specified. Locks and seals threaded fittings. Resists leakage, vibration loosening, moisture, hydraulic fluids and diesel fuels. Lubricates threads for easy assembly and disassembly. Won’t shred or wear like thread seal tape. Parts may be repositioned up to 4 hours after application. Temperature range from -65°F to 400°F (-54°C to 204°C). Contains PTFE.
Suggested Applications: Head bolts into through holes, oil PSI sending units and sensors, oil and coolant lines, fuel fittings, rear axle fill plug, brake and power steering fittings
It says up to 4 hours to 'reposition parts' but I had re-applied torque to the head bolts the next day at someone's suggestion. Just wanna know if I'll be OK, or do I need to redo with a different method and sealant? Just don't want to destroy my freshly rebuilt motor.
Thanks,
~Dave
Thanks,
~Dave
