Stage 2 Twin Turbo
Luckycrash
Okay well I'm just going to come out and say it. I want a twin turbo 800 hp GN. Don't know the specifics of engines, I'm more of a suspension set-up guy, but I was wondering whether to go with a stage 2 motor or a production motor. I'm looking for as much reliability as possible. I remember seeing ESP Performance having a twin-t kit but can't find anything about them anymore on the internet. Please somebody help me out. I was thinking price range in $13000 to $20000. Thanks!
A stage 2 at that power level would be the way to go for long term. Your price range is going to be a little more than that most likely though. I would have Bobby at RPE do the work for you.
Then there is the "LSX" option. THAT would be ultra reliable and meet your financial goals. If you are head strong on keeping a V6, then YES only a StageII will be reliable at that level. You can do it with a girdled 109 block, but reliablility is going to be an issue. But something to consider is that even a StageII will MELT at 800 hp if your tune-up or supporting fuel system is not up to the task. Find one engine builder to do the work, set up the systems and let them tune it. Nick would be a good choice to help you set the WHOLE package up. There are otherfs, too. Duttweiler comes to mind. I'm not sure how many engine builders do the whole package. DLS builds some of the best, but not sure if he installs, plumbs, ect. Call around and get quotes, and find someone with a personality that is willing to help. If you can't get along with them, then it'll be an uphill battle.
$20k might get u started with the motor. add another $50-60k to that to get u started with the rest of the car
So will the LSX.
Billy T.
gnxtc2@aol.com
If going Stage II, a properly built motor well cost what you want a whole car for.
Just a heads up.........
I.M.O., it's no big deal to have a fast LSX motor, everyone and his brother can have one of those!
A hard running Buick Stage II is an accomplishment i.m.o.
Oh no, someone is on another bandwagon!:D
Sheesh. Doesn't anyone know how to shop and swap anymore? :D
Shop smart, be ready to jump on bargains and do a little assembly work yourself, and you can do the engine for 7 or 8 thou.
800 HP doesn't need a tube frame, either. A well-built trans, 3-in driveshaft and beefed up rear will handle that HP level.
Nothing wrong with putting an S2 in a street car.
Yes, you may buy a beat up stage motor and build it for that with welded up crank and used up junk.
A couple local guys went the cheap route and their cars run like ass.....
7-8 for a bargain motor, then buy a turbo,headers,downpipe,intercooler, transmission, rear end, suspension, fuel pump, inj's, efi intake, throttle body, fuel management system,flexplate, balancer, oil pump, fuel lines and fittings etc etc etc, and you'll be done in no time LOL.:biggrin:
If LS is a options give Kurt Urban a call, he is one of the leading LS platform pioneers. You can rest assured he will take the time to talk to you, not down to you and he has forgotten more than some engine builders claim they know!!! :eek:
I usually try to stay out of discussion like this but I just cant seem to help myself. This is the second thread I've seen with a new guy asking how to make a 1000hp and getting his teeth kicked in for being "to cheap" and everyone insisting he use the latest and greatest TB.com superhero engine builder they know and love. What's the matter can't anyone just give out good advise on this board anymore:confused:
I would say Mac is a little optimistic in $7-8k for a motor but he is right shopping around can get you a good deal. Case and point I tried selling this used up junk that nobody wanted and I couldn't give it away
http://www.turbobuick.com/forums/pa...-2-gn1-head-motor-proven-8-sec-tso-combo.html
That same motor is still one of the fastest stock style head Buick motors ever built and I would wager it had more 165+mph passes on it than any other out there.
Making 800hp isn't that difficult and even up to 1000hp is still relatively easy to accomplish with a Buick V6. IMO Going to an LSx based motor at this point is foolish and will end up costing the same if not more. The LSx parts are easier to find and sometimes cheaper but you will still have to buy quality engine parts which are not cheap no matter what you are building AND you will have extra fabrication costs that will likely offset any savings. If you have good mechanical knowledge and some fabrication skills here is my best UNBIASED advise for the do it yourself diehard hot rodder out there that still likes to get his hands dirty:
1. Find a good machinist. I have used several over the years. I would avoid opinionated egotistical "Buick Gods" that will rape your wallet. Straight is straight, round is round and a thou is a thou no matter what planet you live on. There are a lot of reputable builders on this board but I would shop around and talk to a bunch first. Find someone you can work with and who is willing to work with you and not just sell you a "package".
2. If you want to make 1000 hp buy and run a turbo capable of making 1200hp.
3. Forget the 109 block crap over 750hp, find a good S2 block. The stronger ones are on center and most of the off centers are older and really tough to find in decent shape. $2500-$3000 should find you a decent block. I would shy away from something welded and a bore over 4.040 but I wouldnt be afraid of a sleeve if the rest of the block is nice and it was done right. $3k should get you a nice block with no sleeves and a bore 4.020 and under.
At the $3k mark the TA block is something to consider. The additional cost is sometimes worth it for something that can easily be repaired. Plus if you go with a TA you can get an off center which can save some aggravation if you plan to use all the factory components (which you can still do with an oncenter just more work). The block will be your most expensive purchase make it a good one it is the foundation for everything you do from there.
4. Cranks. This will probably be the second most expensive single piece you will buy. Find a nice one. Forgings: the Buick Motorsports BMS that came as a raw forging and many different companies ground them Moldex being one of the more popular. This is probably the best crank to find for the $$. Most say they are good to 1200hp and I agree but I took a 10/10 one way past that mark without any issues. I cant say what the chinese forgings will hold up to but I wouldnt be afraid of them up to 1000hp. They too sometimes need extra attention as far as machining them so be careful and check everything.
A new Crower billet is the way to go IMO if it is in the budget. TA has them on the shelf. If you call Crower direct (especially at the end of the year) you sometimes can get a better deal BUT I would make certain you know what you are ordering as it will be a custom piece!! A new Crower billet is in the $2500 range. There are some decent used billets out there. Some of the roundy round stuff can be rough and has had to much material taken out for a really high HP piece but up to 1000hp you should be fine. f there is a chance you plan to push the motor beyond 1000hp I would buy a new Crower and be done. If not shop around on the boards and maybe even consider one of the chinese pieces.
5. Rods: Buy new buy the crowers or olivers. STAY AWAY from Carillos and anything H-beam (which is the chinese stuff) over 750hp. You sometimes can find 6.5" Crowers, Cunninghams, or Olivers but by the time you rebush them resize them replace hardware etc you are approaching new prices. Plus most used Rods are 6.5" since that is what the roundy round guys liked to use. You may be buying a rod with several 1000 miles of track time or one that has been sitting on the shelf you will never know. You are better off with a 6.300 length rod as you will be able to build a stronger piston. The motor above would still be running today if I had new 6.300 rods in it instead of used 6.500 rods.
6. Pistons: I like J&E and CP's there are others. I had a really bad experience with Diamond. This is one place you want to find a machinist who knows how to spec a severe duty piston for a turbo application. Remember you are building a piston for a 1000hp motor that has 2 less cylinders so that piston will see more severe pressures and heat than a V8 piston would. Use the biggest baddest pins you can find and don't worry about reciprocating weight. I believe I had 220 wall 927 pins and have ruined most all others smaller than that.
7.Camshaft: Lots of mystery here lol. Billet solid roller is your only choice IMO and you will need some heavy springs pressure to go with it. I like wide LSA and longer duration than most. Personally I would call Lonnie Diers and if he isnt doing that stuff anymore I would call Kip Asplund. A lot their designs came from R&D work Lonnie and I did on an engine dyno a few years back and with experimenting with different designs in TSM and TSO motors.
There are few other choices out there and at 1000hp you will probably be alright with some of the more popular grinds available. Figure out your trap RPM for the MPH you want to run with about 10% conv slip and cam and gear accordingly from there. There is more to it than that but that is a good place to start. If you are going to error on the cam error on the small side.
8. Heads: I like stock style and see no reason to run S2's. The S2 heads were not designed for what we are doing with these motors and they require a significant amount of fabrication to make them work. Champion and TA performance are your choices. The Champions are a little less expensive and at 1000hp you will see little to no difference in the two. STAY away from earlier champions I would only buy castings from the last two years and they look noticeably different with extra material cast in the webbing.
If you go with Champion there are several vendors but I would call them direct. If going with TA I would call Kip Asplund or Nick Micale (azgn) plus they both can help spec a cam for the heads and your combo. For a complete set of heads new with rockers hardware pushrods etc you will be North of $4k new. If you shop around you can sometimes find deals.
Champion has a real nice intake if you are running an on center. If you have an off center you can get away with a stocker BUT by the time you are done modifying it you would probably be better off with the champion. Fully ported they are $1000. I ran a 70mm TB to 171mph.
9. Headers: If you want twins get busy with a tig torch as you will be fabricating everything. If you want to run a single get a used set of ATR's and modify them for whatever turbo you plan to run. The larger turbos will require you to cut the end of the header apart to relocate the turbo so it clears everything.
10. Trans/conv. Call Lonnie Diers. He can build a TH400 that'll live to 1200hp fairly reasonable. Once you go beyond 1200hp with a TH400 it gets pretty expensive but under that is pretty cheap. The TQ conv is the SINGLE MOST IMPORTANT PART YOU WILL BUY FOR YOUR CAR. Nothing will affect the cars performance more than the TQ conv so find someone you can work with it may take some trial and error. I would also consider using whoever your trans builder recommends.
There is my best top 10 advise for a 1000hp setup, based strictly on my opinion and experience. Some may agree others may not that is fine. I would say motor alone on a budget shopping for deals can be built in the $10k range with a top notch piece in the $15-18k range. If you get it done for $10k (which'll take time and searching) you can probably get everything done with in the $20k budget but you will be doing most of the work yourself and that is providing you already have the car and a lot of the basic safety stuff in place like a roll cage, rims tires etc.
Good Luck I hope this was informative.
Bottom line......building from scratch costs a lot of $$$$$$$$, best to buy a car already done and hope it's built properly.
You will most likely save thousands on buying one already built, good luck on your search.
If you want a properly built stage II car they can be had for 30-35k.
Good info Chris.
However, I read that he is NOT an engine guy and doesn't know what he is doing. If you are not a VERY experienced engine builder, I wouldn't suggest stepping into a Buick V6 high HP build. Helll I know great engine builders that can't keep a Buick V6 alive to save their own butt. Very few builders have a clue on how to machine/assemble a big power Buick. It's NOT rocket science by ANY stretch, but why do machinists always seem to kill these things. That was why I suggested a reputable builder. But even the best machined, best assembled engine will FAIL if not tuned right. Yep, even an LSX;)
But then if the guy wants to do the work himself, we all should be there to help.
.......... Please somebody help me out. I was thinking price range in $13000 to $20000. Thanks!
Here is what you can get for $18K. If you make it an even $20k we will do custom SS twin turbo headers.
For your info this fresh build has a billet Crower 3.625" crank, Crower rods, JE pistons and all the other internals to handle in excess of 1400 HP!
You are correct! Stage 2 stuff is selling cheap you just have to keep an eye in the parts for sale. I just sold a new unused oncenter stage motor, crank,rods,heads,rockers,intake etc for 4k. I listed it for 5k no offers 4k sold it.
Sold a complete set of stage 2 heads with rockers, off center efi intake for 1k
http://www.turbobuick.com/forums/parts-sale/342179-fresh-na-center-stage-2-motor-complete-cheap.html
Off the shelf LSX parts are cheap and reliable making 1000hp easy!
Drop a LSX in your GN it's still a Turbo Buick, you will save a ton of $$$ and headaches.
I think i really need that!! I was about to pull trigger on building alluminum block. But that seems to be ticket:biggrin:
:eek: Yes pleaseeee
You could buy the car in my sig pic and description for 22,500. Its a turn key low ten second car. As it sits. Turn up the tune and run nines. It makes 7-750 horse. All the good stuff. Great on the street. Fast at the track. Girdled block, gn1 heads. TA headers etc. Ice cold AC. All power options. Lemme know. Everything is for sale. Jay.
