- Jun 18, 2001
This is the motor that is currently in my TSO car and can be heard running and seen running at Norwalk. To date it has 3 330' runs adn two dyno pulls. It made 899@20psi and 977@28psi on dyno and has A LOT more left in it. Combo has been 8.55@163 previously and will go faster with the recent updates. I plan to run this motor for Norwalk and it is also for sale along with the complete car. After Norwalk it is coming out to make room for the new setup along with the chassis update for the car. This is a complete setup no guess work no R&D no tuning, drop in and run 8's!
Engine:
153 On center S2 4.015" bore one sleeve no repairs or damage cross bolt front and rear
Pistons Custom CP from DLS
Crank Billet 3.59 LA Enterprises
Crower Billet Rods
Rollmaster timing chain
Custom Extreme Automatics billet roller cam
Smith Brothers pushrods
Champion GN1 Heads extensively modified by both Champion and Extreme Automatics. Heads have many many 8 second passes without cracking and on last inspection still have a clean bill of health. Heads have relocated exhaust port with extra material in crack prone areas. They are a custom casting from Champion have relocated spark plug location different CC and flow better than any other GN1 head I've seen or tested.
T&D shaft rockers
Champion intake custom ported
70mm TB
BHJ Balancer
JW Flexplate
Powder coated champion valve covers
Oil System
CAS Sheetmetal oil pan
-4an rear cyl head drain back
Duttwieller oil pump w extensive modifcations and custom coatings
All oil lines
$15000
Fuel System:
160# injectors
Weldon regulator
Accel Gen 7 engine management with Extreme Automatics tuning
Accel WBO2 controller and internal datalogger with NTK sensor
Custom engine wiring harness for GN and above setup
$1900
Ignition:
MSD Distributor
Moroso wires with sleeves
Accel DFI 6A ingintion box
Accel DFI coil
$700
Turbo/Exhaust:
PTE T4 4788 $1600
ATR headers modified for T4 turbo and plumbed for EGT probes jet hot coated
Tail 44mm wastegate
Custom 4" SS downpipe with 4" "muffler and turndown $1600
Innovative MSBC (latest version) complete with selenoids etc $400
CAS V1 intercooler with pipes and hoses. IC is in good shape but has some battle scars on it still works fine and is one of he best IC's we've tesed. $700
Or I will sell the complete package above for $19,500 which is essentially everything under the hood of my GN minus the radiator & fan setup. I am not interested in parting out the components until the long block is sold.
Engine:
Crower Billet Rods
T&D shaft rockers
70mm TB
BHJ Balancer
JW Flexplate
Oil System
All oil lines
$15000
Fuel System:
160# injectors
Weldon regulator
$1900
Ignition:
MSD Distributor
Accel DFI coil
$700
Turbo/Exhaust:
PTE T4 4788 $1600
Tail 44mm wastegate
